Edelbrock Carb on stock intake
Old May 26, 2005 | 09:52 PM
LandryP's Avatar
Is there a way to mount a performer series carb to a stock egr intake? I tried to fit one up tonight and it seemed that no mater what the shaft for the secondarys would hit the egr valve iregardless of how thick a spacer/adapter was used.
Pat
Old May 27, 2005 | 08:58 AM
85_305's Avatar
Re: Edelbrock Carb on stock intake
The only way for an Edelbrock carb to fit on the original intake manny is to buy a square-bore adapter.
Hey, that reminds me; I have one sitting in my room right now; gaskets, screws and all
Old May 27, 2005 | 10:46 AM
LandryP's Avatar
Hmm, even with the adapter (1 in) I'm pretty sure it will still hit the Egr I guess I'll give the Q-jet one more shot
Old May 27, 2005 | 08:50 PM
89_Irocz's Avatar
You can always use a egr block off plate....... That's if you don't mind diching the egr...
Old May 27, 2005 | 11:25 PM
Zepher's Avatar
I used a 1" adaptor and blocked off the EGR when I went from the qjet to the Edelbrock.
I also changed the distributor to a vacuum advanced unit.
Old May 28, 2005 | 11:18 PM
BadBowS10's Avatar
At work some dude had me put an edelbrock 600 on his 82 olds 307. I used an adapter plate just to raise it and then used a die grinder with a debur bit and clearanced aroudn the egr base worked like a charm
greg
canbaufo
May 25, 2015 12:01 PM
Noer
Feb 28, 2015 11:29 AM
CARiD
Jan 27, 2015 06:27 AM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
