Got a Code 32...
Old May 10, 2005 | 10:41 AM
mako350Z28's Avatar
Got a Code 32...
I have been having problems with the IAC valve so on Sunday I took it out and cleaned it. That didn't work so I replaced it. The car idles perfectly but for some reason the check engine light came on. Checked it out and it came up as a code 32. The thing is, I just replaced the EGR valve 6 months ago amd the car still runs like it is new. Any thoughts or suggestions?
Old May 10, 2005 | 11:29 AM
Bristol's Avatar
Re: Got a Code 32...
I had the same issue but only came on at freeway speeds. I too changed the valve etc. but mine turned out to be the EGR solonoid mounted to the coil bracket.
Old May 10, 2005 | 01:14 PM
mako350Z28's Avatar
Never mind I found the problem. When I put the throttle body back on I missed a vacuum line on the bottom of it.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
