Horn Button Problem
Old Jun 9, 2005 | 12:01 PM
Tom87IROC's Avatar
Horn Button Problem
While driving down the road, after hitting a bump, my horn started beeping. I hit the horn button to shut it off but this time that did not work. In a panic, I pulled the button towards me and disconnected the button from the steering column. How do I put this back? There are 3 posts that look like I can dab some silicon to hold the button onto the metal disk. Does this sound feasible? Any help would be appreciated.
Old Jun 10, 2005 | 03:06 PM
Phantomfe3's Avatar
Re: Horn Button Problem
it just presses on, you dont have to clue it or anything, just stick it back on there
Old Jun 10, 2005 | 05:21 PM
LesPaulGoth's Avatar
I dont think youd want to glue it...then if you needed to get it back off, you wouldnt be able to...unless you used a weak type of glue.
Old Jun 10, 2005 | 06:56 PM
Wpns Grd Plutonium's Avatar
BAHAHAHA I did the exact same thing to my 89 IROC!! Everytime I turned a corner or went over a bump, the horn would honk. It got worse and worse until one night I turned a corner and the horn stayed on so I yanked it off.
And yeah you will have to glue it back on. It doesn't just "stick back on". It requires glue.
Old Jun 11, 2005 | 01:10 PM
Tom87IROC's Avatar
I am only talking about silicon on the 3 posts on the backside of the horn button where it must have been connected from the factory. Yours probably does not come apart, but I ripped my off by hand to stop the horn from beeping. I am not glueing the button to the steering column. I still can connect the button to the column by the clips.
DirtyDaveW
Dec 1, 2016 05:37 PM
PCLZ28
Dec 24, 2015 05:19 PM
sahlomonic
Parts Wanted
Sep 19, 2015 10:17 AM
fpete1992
Dec 11, 2014 03:51 PM
tds1213
Nov 27, 2014 12:55 PM
