converter question
Old Jan 31, 2004 | 08:12 AM
BlownRedz28's Avatar
converter question
I bought a Midwest converter for my supercharged Lt1 and it is suppose to foot brake stall 3000 on et streets at the track, but I havent had it to the track to know.Right now on the street with the et's it only stalls 2300 before the tires broke loose. I have only had it in a day and I was wondering if it would loosen in up any.
Old Jan 31, 2004 | 09:12 AM
rskrause's Avatar
Moderator
Re: converter question
On a stickier surface it will brake stall higher. But it's very hard to predict exactly where a given converter will brake stall on a given car unless you have tested it on a very similar combo under similar circumstances. Converters do not loosen up with use though.
rich Krause
Old Jan 31, 2004 | 11:00 AM
ok thanks for the info, will programming change anything because I get tht done by pcmforless.
Old Jan 31, 2004 | 11:46 AM
QCKZ28's Avatar
is it a midwest 3000? the stall rating is true stall, not brake stall.
the only way to get close to true stall is with a transbrake.
programming will help with the shifts.
my Vigilante 2800 "brake stalls" only to 2000rpm.....
so 2300 sounds about right for a 3000 stall
jesse
Old Jan 31, 2004 | 03:22 PM
rskrause's Avatar
Moderator
Programming will not change the stall speed of the converter.
Rich Krause
Old Jan 31, 2004 | 05:17 PM
the stall rating is 3400-3600 and I told him I wanted it to foot brake stall 3000 at the track on et's.
Old Jan 31, 2004 | 10:27 PM
QCKZ28's Avatar
have you tried heating your tires and see what it stalls to?
you do have a tranny cooler right?
jesse
Old Feb 1, 2004 | 09:35 AM
yeah I heated the tires some but the road wasnt that good so I hoping that is the problem. I do have a tranny cooler installed
ChrisFrez
Feb 15, 2015 07:49 AM
rwferguson43026
Feb 6, 2015 10:06 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
86ZZ4
Aug 22, 2002 08:50 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
