speedo and 3.73
Old Jan 9, 2004 | 03:51 PM
djlup's Avatar
Question speedo and 3.73
Hello all,
I have a 93 z28 that has 3.73 gears in the rear. Currently the speedo is off by about 10 mph. I would like to correct this by replacing the gear in the transmission. Does anyone know what size gear I need to look for?
More info
old rear: 3.23
new rear: 3.73
trans: th700r-4 "auto"
please let me know if there is anything more you need to know
Thanks,
Dennis
Old Jan 9, 2004 | 04:34 PM
djlup's Avatar
Smile
After doing a little research on [url]www.speeddensity.org[url] I found out the gears that are swapped out in the 93 700R4 trannies are called the drive and driven gears. The part numbers are as follows:
GM p/n 25513052 (44 tooth driven gear) $12.78
GM p/n 8642620 (15 tooth drive gear) $7.56
Can anyone confirm this?
by the way the info was gathered from a post by knightfire on speeddensity.org props to him.
93 RedBird
Nov 15, 2015 08:24 AM
4586
Sep 27, 2015 01:55 PM
SEOJustin
Sep 24, 2015 04:39 PM
mmf_1013
Sep 12, 2015 08:56 PM
cristian1311
Sep 12, 2015 08:16 PM
