Transmission guys inside please ~~~~>
Old Feb 6, 2004 | 09:18 AM
ONELOUDKAR's Avatar
Arrow Transmission guys inside please ~~~~>
The tranny has been re-built... everything has been replaced.. still cant get the 2-3 to shift under WOT. Could this be a faulty
tranny or could it be a bad PCM? Bryan at pcmforless was in the
car programming it and he said he has never seen one this bad.
What could be wrong with it? Its pretty much done this since day one when i started to race the car. Some input would be much
appreciated right now.
-Mike
Old Feb 6, 2004 | 11:54 AM
tellum's Avatar
sounds a lot like my problem
read this
http://web.camaross.com/forums/showt...80#post1794580
Old Feb 6, 2004 | 12:40 PM
ONELOUDKAR's Avatar
What are the sings of a bad PCM? You know it really sucks when you are racing and cant even get your car into 3rd w/o it pegging the dayum limit EVERY TIME. Someone here has to have some input on what the problem could be.
-Mike
Old Feb 6, 2004 | 12:58 PM
tellum's Avatar
yeah i dont know. I have the same problem with my old tranny and my new one...im convinced its something electrical but i dont even know where to start.
Old Feb 6, 2004 | 01:38 PM
ONELOUDKAR's Avatar
well i dont understand why no-one is wanting to help out on this one. i know there has to be some tranny guys that have delt with this problem.
Old Jun 2, 2005 | 07:25 PM
da_gringo's Avatar
Re: Transmission guys inside please ~~~~>
i had the same problems with mine, the rebuilder installed a 12 pin plug (purple) rather than a 13 pin (green).
if you look at http://www.transmissioncenter.net/4L60E.htm
you will notice the elecronics are differant for a 95 and unique for a 95.
search for part# 60E5
Old Jun 3, 2005 | 05:11 PM
12SCNDZ's Avatar
This is a common problem on "generic" rebuilt 4L60E's. Most builders don't know how to solve the problem. Those of us who spewcialize in building race 4L60Es know how to solve the problem. By the way...The cause of the problem is internal...Which means the transmission has to come back out to fix it.
Frank
Old Jun 5, 2005 | 06:26 AM
Pro Built Automatics's Avatar
The problem is internal ok, it is normally too much 3-4 clutch clearance, to little 3rd gear accumulation, not enough feed oil going to the 3-4 clutch pack, etc. There are fixes for this, let me know if I can be of help?
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
rocketman051894
Jan 30, 2015 03:23 PM
mspennyhughes
Nov 28, 2014 03:22 PM
squarehead
Nov 21, 2014 08:02 PM
Red97LT1
Aug 7, 2002 05:45 PM
