3.73 question
Old Jan 29, 2004 | 08:13 AM
Eliminator's Avatar
3.73 question
I have a 1994 auto with 2.73 is there a way to tell if you have a 7.5 or 8.5 without opening your rearend up. I call a Chevy tech and he said the only way is to measure it once its taken apart. True or false, Thanks
Old Jan 29, 2004 | 10:04 AM
aintno6's Avatar
its a 7.5 inch. when you order your gears, you will need to order them for 7.5 or 7 1/2 inch 10 bolt, for the 2-series carrier. 3-series carrier, is for the guys with 3.23's stock.
Old Jan 29, 2004 | 02:59 PM
Capn Pete's Avatar
Well, you could take it apart to find out, but since it's a 4th-gen, you should already know that it's gonna be the 7-1/2" 10-bolt. I don't think anything bigger came in F-bodies since 2nd-gens, which still had the 8-1/2" 10-bolt.
As was just stated above, you need to order 3.73's for a 2-series carrier...........not a problem, as most brands build for 2-series and 3-series carriers.
Old Jan 29, 2004 | 07:16 PM
Eliminator's Avatar
The GM tech told me it came with both for the 2.73 7.5 and 8.5 and the only way was to take it apart to measure it. I might call another Chevy palce to ask a different Tech. Thanks for the replies.
Old Jan 29, 2004 | 09:04 PM
Capn Pete's Avatar
Not a '94 . That would be the biggest "news" I've heard in a long time if that were true! Trust me dude, you've got the 7.5" just like the rest of us . That's why everyone upgrades to 12-bolt diffs eventually.
Old Jan 30, 2004 | 08:06 PM
Eliminator's Avatar
Thanks for the info.
Old Jan 31, 2004 | 05:32 PM
79TTCAMARO's Avatar
The only camaro that came with an 8.5 rear since 81 is the 1LE cars. You would know if you had that car.
Old Jan 31, 2004 | 09:22 PM
Eliminator's Avatar
This is whats scary he works on cars and gives me wrong info yikes.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
blac94Z
29
Mar 25, 2015 04:21 PM
