My tires stick out too far on one side....
Old Jan 31, 2004 | 04:07 PM
PsychoJavexx's Avatar
My back passenger tire sticks out an inch or so more than the other one. We checked around and found that the frame (or a piece of metal) was bent. They said I could bend it back, or get an adjustable... thing (I don't know what it's called).
Which would be easier? And if I got something that would be adjustable, how could you keep it in place?
Old Jan 31, 2004 | 04:26 PM
RacinLT1's Avatar
adjustable panhard bar will solve the problem. it bolts in where the stock 1 goes,and uses JAM nuts to keep it from moving once you set it.
Old Jan 31, 2004 | 06:18 PM
Thanks a lot. I'll pick one up sometime soon.
But now I've noticed another problem, right after I posted. Heh, my front does the same thing. Is there anything I can adjust in the front to fix that too? It sticks out a little bit on the passenger side as well..
Old Jan 31, 2004 | 06:36 PM
RacinLT1's Avatar
i've never seen the front stick out unless they used spacers. nothing can be easily done to correct that.
Old Jan 31, 2004 | 06:57 PM
Man... damn. lol
I'm going to check and see if those rims are all the same width. I traded rims with a guy a few months ago, and I have no idea how wide they are. Maybe the ones I put on the passenger side are wider? Maybe, I don't know.
And by spacers, you mean.. what? lol I'm sorry for the stupid questions, but I don't know a lot about cars, obviously. Thanks again though.
Old Feb 1, 2004 | 10:07 AM
bowtiepwr's Avatar
>If you can , maybe go to an alignment shop with the laser and see if the car isn't bent . Normally people used these for the drag racing skinny wheels so the spacers are used to offset the wheels from hitting (example) brake calipers/drums . They are just like using a spacer for anything else for the clearance .
adjustable panhard rods are available from alot of manufacturers like BMR ( http://www.bmrfabrication.com/F-body...tm#panhardrods )
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Boss002
Jul 9, 2015 03:33 PM
Slayer
Jul 4, 2015 03:06 PM
Cam's maro
Dec 29, 2014 08:44 AM
