abs delete
Old Jan 31, 2004 | 06:16 PM
crzhrs's Avatar
abs delete
Figured I would ask this question here since the main reason someone would delete their abs is for a 12 bolt swap. What all is involved and what problems does it cause? Can you keep the front abs if you swap in a nonabs rear?
Old Jan 31, 2004 | 06:37 PM
RacinLT1's Avatar
as far as completely removing it,havent done that yet,and mines been dead for 2 years.
you cant keep front abs without the rear,it's a 3 or 4 channel system,and as soon as 1 channel is removed/in trouble the whole unit is dead.
Old Feb 1, 2004 | 10:17 PM
crzhrs's Avatar
So, does it cause any problems? Other than being able to lock up your brakes.(if you call that a problem) Do you just disconnect it from the rear?
Old Feb 2, 2004 | 01:34 AM
Z95m6's Avatar
why not just build your own abs set up so you can keep it with a diff rear end?
Old Feb 2, 2004 | 01:50 AM
JWBerk94Z's Avatar
Please pardon my ignorance, but how would you do that?
Old Feb 2, 2004 | 08:01 AM
Sean94Z's Avatar
It's easy to remove. Basically, you disconnect the lines running to the ABS module, then tee the front 2 lines together, and run them to the master cylinder. Then, run the rear one to a proportioning valve and connect that to the master cylinder..
Pressto, no more ABS.. Now is the perfect time to put a line lock in though.. Check out this site, they have some line lock install kits that can help, it's a bitch to bend all the lines and make the flares right..
http://www.mycamaroz28.homestead.com/
--Sean
Old Feb 2, 2004 | 09:48 AM
crzhrs's Avatar
I would like that homemade abs recipe as well.
Old Feb 2, 2004 | 11:17 AM
chpmnsws6's Avatar
know anyone with pictures or items needed to buy or a kit we can buy?
i have the stock rear end but hate my ABS and it would be nice to get rid of the added lil bit of weight
Old Feb 2, 2004 | 06:35 PM
Z95m6's Avatar
http://web.camaross.com/forums/showt...hreadid=169674
I do have the original email given to me that showed how to do it if anyone needs anything further i can email it to them.
IndyZman
Oct 22, 2015 02:17 PM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
realistyc
Jul 28, 2015 07:32 PM
