Leak
Old Sep 11, 2003 | 01:34 PM
DC89IROC-Z's Avatar
Unhappy Leak
I have a leak coming from my crank. I am not a mechanic by any means. I'm wondering is this tough to fix? Is it expensive?
Old Sep 11, 2003 | 01:40 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Re: Leak
How can you have a leak from your crank? You mean oil pan, Rear Main seal?
Clarify please.
Old Sep 11, 2003 | 02:02 PM
DC89IROC-Z's Avatar
I don't know. That's what my boy said. It's not the oil pan, it's a case in front of my driveshaft. it has wetness around it. I have no idea what it is. I was told it was the crank case. Iwish I still had my digital camera I would post a pic. I'll try to borrow one and post it so you can see.
Old Sep 11, 2003 | 02:21 PM
aklim's Avatar
Cam seal maybe?
Old Sep 11, 2003 | 06:47 PM
lordmetalz28's Avatar
rear pinion seal. are the tires connected to this supposed crank.
if so its your pinion seal. if so most likely cause your bearing is shot like mean no rush keep it topped off and rebuild when you can with better gears
Old Sep 11, 2003 | 08:41 PM
Rice Killer87's Avatar
if u mean in FRONT of the driveshaft,as in front of the car,thats the transmission pan. theres a gasket between it and the transmission that goes bad on every car that has average/decent mileage on it. u can replace it if u want,or just keep checking the trans. fluid once or twice a week.
Old Sep 11, 2003 | 09:04 PM
slayer6x6's Avatar
Wait, is he leaking motor oil, atf, or gear oil? Im confused
Jeff1904
Jun 5, 2016 05:00 PM
magman
Apr 15, 2016 03:08 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
