how to find cam specs...
Old Sep 17, 2003 | 07:58 PM
IROC350's Avatar
when i bought my car, the guy before me had tinkered with it. i have a cam in my car and other bolt-ons but can only pull out 9.4-9.5's. i'm looking into getting a chip programmed for the car to see if that's the problem. however, i don't know the specs of the cam. is there a way to find out? i'm looking at doing this thru PCM For Less.
Old Sep 17, 2003 | 08:00 PM
Black6SpdTA's Avatar
As far as I know, you can't. Unless you pull it and get some really high tech expensive measuring tools. What's your trap speed?
-Rippin
Old Sep 17, 2003 | 08:18 PM
IROC350's Avatar
my fastest was 75mph in the 1/8th.
Old Sep 17, 2003 | 10:29 PM
aklim's Avatar
What should it matter? If they take readings, they can tell what the car is doing. Fasterproms used my spec sheet to get close and sent me a chip. It took 2 more burnings to get it nuts on. How is PCM for less doing it? I don't know of any other way to do it to get a truely custom chip. Lingenfelter once took my car for a day to get it dialed in just perfect. If they really need that spec sheet from the cam, they may not be doing a truely custom chip. What do they want for their work? Fasterproms is at $350 and the next time you need to go thru the process again, it is $150. Once it is dialed in just perfect, it should not need to be reburnt unless you do something radical.
AdsoYo
May 2, 2018 03:21 AM
HectorM52
Jul 30, 2017 11:46 AM
pimpss96
Feb 12, 2015 01:28 PM
chuyz28
Jan 15, 2015 04:14 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
