Heeeeellllppppp!!!!!
Old Sep 16, 2003 | 11:34 PM
gfrankel's Avatar
Exclamation Heeeeellllppppp!!!!!
I installed a new cap and rotor, an spark plug wires. I have an 84 Z with the 305 quadrapuke. I installed a new cap, rotor, and spark plug wires. The car now will not start, and when it does finally start it runs like @$$ and throws a code 32 (baro sensor voltage low). It was running just fine before I changed that stuff. Can anyone tell me what the problem could be?? Any suggestion would be most appreciated.
Old Sep 17, 2003 | 12:16 AM
Dave89IROC's Avatar
make sure you did not knock the wires or the vac line off the MAP sensor, which is used for a baro reading, it might be on the firewall to the passenger side from the distributor
Old Sep 17, 2003 | 04:36 PM
Brit Iroc's Avatar
I know , I know but....are the plug wires on right?.
Old Sep 17, 2003 | 05:58 PM
TheGreatJ's Avatar
It sounds like a loose vac line to the MAP sensor. Check that, and if it's good check your wires....a misfire through the intake can cause a sudden sharp drop in vacuum that will trigger a code 32.
Old Sep 17, 2003 | 09:20 PM
lordmetalz28's Avatar
sounds like you got the ignition wires mixed up get the diagram and go over it youll be surprised
Old Sep 18, 2003 | 12:52 AM
gfrankel's Avatar
distributor got off 2 teeth. I dont know how, but that is what the fault was. Thanx for all the help.
