Help!
Old Sep 6, 2003 | 09:51 PM
84t-topZ's Avatar
Help!
The exhaust pipe broke right behind the cat. Before the pipe broke we heard a sound coming from the general area of the catmaybe the back 2 cylinders. Its a sort of ch!nk ch!nk ch!nk sound. it doest seem like anything in the valve train broke the car still runs fine considering its age and milage.
ANY suggestions as to what can cause this noise will be greatly appreciated
Thank you in advance
-Dave
Old Sep 6, 2003 | 10:24 PM
BigCasino87GTA's Avatar
From: Chillin' with Frank, Dino, Sammy and Pete at the Sands!
that might have been the exhaust rattling/vibrating right up through the Y-pipe when your exhaust was in the process of giving way. Just before it broke, it might have shook a bit and rattled your whole exhaust system right up to the manifold - giving you the impression that the noise was coming from the two rear cylinders - this is just speculation though.
Old Sep 7, 2003 | 08:34 AM
84t-topZ's Avatar
Thank you for the speedy reply. The ch!nking sound i heard is still there even after the pipe broke so any more suggestions?
Old Sep 7, 2003 | 02:30 PM
I'd get under there and take a look, sounds like something is hanging loose and clinging and clanging against the underside of the car.
Old Sep 7, 2003 | 03:32 PM
84t-topZ's Avatar
Well.........................
I did just that
got under there
actually was under there all day tryin to replace that damn pipe that broke.
I didnt see anything loose.
so i guess im going to wait till i get her to new york and then replace the motor like i planned anyway
it DOES have 248 thousand miles on it
Old Sep 7, 2003 | 03:43 PM
StealthElephant's Avatar
Sounds like a bad exhaust pipe...when I dropped my Y-pipe I found it was split along the top...my car had started to get louder and louder and a metal clank was audible when I went over a bump...
Old Sep 7, 2003 | 03:44 PM
84t-topZ's Avatar
stealth you looking to sell that 305?
