Do hydraulic flat tappet cams make power?
There's an engine for sale now on ebay but it uses a hydraulic flat tappet cam.. should I go for it?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2429947481
Location: Teeter-tottering between Brilliance and Insanity
Sure they do, thats what most people with small blocks run. Solid, and roller cams enable you to run higher numbers (lift etc) But hydralic cams, are much less matenence. A solid lift cam you have to adjust regularly.
Edit: If you buy that engine though, dont use the TBI its built for. Unless your putting it in a truck or something.
Originally posted by 96cam4ro
Why not? Since I've already got the TBI..
No way is that cam going to make those power numbers with stock heads and a TBI unit - just ain't gonna happen. You can do better for less $. The roller has a few small benefits over the roller cam setup. But IMO the small HP gain you will see is not worth the high inital cost. The money you save in the valvetrain can be put elsewhere with greater rewards.
That engine would probably get you into the low 15s high 14s with the rest of the drive train stock. For the price, just go to a local machine shop and get one built, or DIY for even less.
Check with GM (local dealership parts dept should be able to hook you up), the 330 HP HO engine w/Vortec heads runs about what they're asking for that engine.
12486041 330HP / 350 GM Performance Parts Crate Engine Assembly $2,299.90
That was at:
http://www.sdpc2000.com/cart.asp?act...id=120&pid=115
If you go stock you can get a complete Goodwrench engine for under $2k and long blocks for a little over $1k. Then you also have a warranty backed by GM.
That was at:
How much money does it take for a thirdgen to get into the 12's using a crate motor with a carb? How's the drivability and gas mileage? Does anybody have RWHP numbers?
10-31-2016 11:09 AM
