New steering wheel...air bag ??
Old Sep 11, 2003 | 12:15 PM
shwine617's Avatar
I am getting a new steering wheel but i am afraid to change it because i dunno if the airbag is gonna blow up in my face. I don't even know if the airbag is still in it. but if there is , how should i aproach this, without getting the **** scared out of me if the airbag blows.
thanks!
Old Sep 11, 2003 | 03:18 PM
caspergotaz28's Avatar
There should be a fuse and/or relay you can pull that coincides with the airbag. Make sure to disconnect your battery also. Also try and remove the bag sitting in the passenger seat just in case.
Old Sep 11, 2003 | 04:07 PM
aklim's Avatar
Is there one in the passenger seat for the 3rd Gens? Mine (91) didn't have it. In any case, get a Chilton book and they will tell you how to.
Old Sep 11, 2003 | 05:18 PM
kandied91z's Avatar
removing all the power connections is the best bet....i know when i replaced my wheel i was pretty much laying as low as possible to avoid an accident. everything went smoothly but you never know.
Old Sep 11, 2003 | 05:29 PM
aklim's Avatar
You could remove the battery but the DERM still has enough charge in the capacitors to fire the airbag. This is in case you have a crash which damages the battery and have a second crash in the same accident.
Old Sep 11, 2003 | 07:07 PM
shwine617's Avatar
where do you put the wires from the air bag after?
also how could u tell if the airbag was deployed and isn't there anymore?
thanks
Old Sep 11, 2003 | 07:24 PM
Black6SpdTA's Avatar
thanks
Once all the connections are disconnected and you pop the actual bag off (the middle part that says "Camaro") you'll see the bag material. First check if on your dash the light lights up that says something like INFLRST, if so it means there's no bag or it was installed incorrectly. Good luck don't let her blow on you!
-Rippin
rideordie
Sep 7, 2015 08:22 AM
War Engine
Aug 28, 2015 06:04 AM
Schul365
Aug 25, 2015 05:47 PM
Jul 17, 2015 02:47 PM
camaro02DK
Jul 5, 2015 09:24 AM
