Other than the stroker crank what do I need?
Old Sep 15, 2003 | 09:18 PM
nuck's Avatar
I see one of the local shops has Scat 383 cranks for $200CDN. Starting with a 350 block and rods, what else is required? Using a non roller cam is one 350 block pretty much the same as another? I assume the 305 block wil not accomodate the extra stroke. Anyone?
Old Sep 15, 2003 | 09:29 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
You need differnet pistons, with a shorter compression height. No big deal they are so pupular nowadays they can be had almost as cheap as regular 350 pistons.
Other than crank and rods, all you really need is a little machine work, clerancing and making the bore 4.030.
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
13qtr
Jul 19, 2015 05:30 PM
94Form
Jul 17, 2015 10:56 PM
Catmaigne
Jul 14, 2015 05:17 PM
