Which Shift Kit Should I Get?
Old Sep 12, 2003 | 06:00 PM
dj haf's Avatar
as the subject says... which shift kit should i go with when choosing one? which is the best? im putting it on my 1990 iroc-z 5.7... thanks guy
Old Sep 12, 2003 | 06:07 PM
Pro Built Automatics's Avatar
Go to http://www.pro-built.net/index.cfm?f...&categoryid=83 this should give you some ideas.
Old Sep 12, 2003 | 07:59 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Everyone Ive talked to says get teh TCI one. They all say the B&M kit for the 700 R4s makes them fall apart quickly for osme reason
Old Sep 12, 2003 | 10:30 PM
aklim's Avatar
How about waiting for a rebuild then get it done at the same time? I got Rossler Trans to do it and they set it up so it shifts hard all the time. You can get it to shift soft all the time, hard at WOT only or hard all the time.
Old Sep 12, 2003 | 10:43 PM
unvc92camarors's Avatar
you can get nice shifts at part throttle and firm wot shifts w/the transgo kit from pro-built
don't get b&m whatever you do, all their shift kits do is increase line pressure, which for some reason makes the tranny fall apart very quickly
Old Sep 13, 2003 | 08:38 PM
IZ28's Avatar
Trans-Go and nothing else.
Old Sep 16, 2003 | 03:37 AM
hairbear's Avatar
Why waste your time opening the tyranny up until it needs rebuilt. Just get a Fairbanks Piston/Servo kit. It's alot better than that crappy vette servo and you'll not even want a cheap shift kit after feeling it shift with fairbanks installed.
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
RedLineRev
Jan 23, 2003 03:51 PM
TrouserSnake
Aug 7, 2002 12:43 PM
