Engine Panning help
Old Aug 30, 2003 | 01:01 PM
Dave89IROC's Avatar
Engine Panning help
Ok, I need help on cam selection and any thing you think would be better different, let me know
this will be a 383
350 .030 over....1 piece rear main, 2 bolt converted to splayed 4 bolt
Eagle forged steel crank, 3.75 stroke
Eagle ESP 5.7 rods
Forged pistons 10.5:1-11:1 CR..........suggestions on brand?
Fluid Dampr
Cam? will be Roller
Steel roller rockers Comp Cam?
AFR heads........190/195? or more?
Fuel Injection..HSR?LT1?or aftermarket(i.e. carb style manifold w/4 barrel TB)?
Hooker Super Comp Long Tube Headers(ceramic coated)
700R4 from www.pro-built.net
stall convertor as recommended by manufacturer..........Ideas on Man.?
ok, any ideas on what cam I should get?
It will be street driven, not a daily driver, but driven often in summer
This will be going in a (my) 89 IROC,
will get a roll bar (maybe a cage)
If needed(probably will) I will get a Moser 12 bolt
Any ideas on rough HP?
Old Aug 30, 2003 | 04:34 PM
RabidDog24's Avatar
w/ that set-up, get some high lift in that bumpstick.
Old Aug 30, 2003 | 05:32 PM
oil pan 4's Avatar
230/230 is a good duration for a not quite super hot 350 I think thats what it looks like your after.
Also get some 1.65 rockers for even more lift if your into that kind of thing.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
dale3in98
Feb 14, 2015 12:18 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
siguy
Nov 27, 2014 10:07 AM
