small blocks interchangeable on the outside
i diddnt know what to tittle this post but anyway are the engine mounts the same with all the GM engines like the pontiac 400's and the oldmobile 350 and of course the chevy 350? basically are all small blocks interchangeable on the outside?
The Chevrolet smallblocks (283,305,327,350,383,400) are pretty thoroughly interchangable. They do NOT interchange with the BOP (Buick, Olds, Pontiac) line of engines. They also don't interchange with Caddillac specific (i.e. 4.9l Northstar) engines. The BOP engines should interchange with each other...Caddy motors are on their own which is one reason parts are so expensive.
262, 265, 267, 283, 302, 305, 307, 327, 350, and 400 are the OEM SBC offerings.
There is no such thing as a big or small block Pontiac, they are just Pontiac engines (unless you count the 301, which is the scourge of GM engines), the die hard Pontiac guys get upset if you call them big or small blocks.
Oh and you can bolt a BOP tranny to a SBC. Only two bolts line up, but I have done it on Demo Derby and Figure 8 cars (NOT RECOMMENDED).
Martin
Martin
From: Teeter-tottering between Brilliance and Insanity
Martin
Martin
(And its not a mopar)But what about the other two BOP makes, someone was saying that the 403 is a small block and 455 is a big block in olds. Do buick and olds use diferent sized blocks.
carguyshu
Jan 22, 2017 11:19 AM
But other than that hes right, just incase you wanted conformation.
