Quesion about a 87 IROC
Old Sep 17, 2003 | 06:16 PM
SantaCruz163's Avatar
Ok, theres a IROC i'm going to look at Friday and the guy saying it said that it turns over but doesn't fire. He said it's getting spark. It's a 350 carb engine, so I'm guessing 1 of the jets might be stuck, he said it sat since the begining of summer. Do you guys have any advise what I should do when I look at this. Here it is
Old Sep 17, 2003 | 06:20 PM
Strahley's Avatar
Wow that's a good deal, 2700 bucks. I'd buy it!
As far as engine goes, couldn't tell ya. Don't know squat 'bout a carb engine
Old Sep 17, 2003 | 06:32 PM
$2300 and he might be willing to go to $2000 Anyone else. I need some advise
Old Sep 17, 2003 | 07:54 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Timing might be 180* off if hes getting spark and its not turning over. I say go for it, pretty car.
Old Sep 17, 2003 | 09:11 PM
Nah the timing isn't out. He said that he stopped driving it at the begining of summer and it drove great. I guessing it's just something with the carb. Could it be the fuel pump?
Old Sep 17, 2003 | 09:17 PM
lordmetalz28's Avatar
fuel pump def i got my iroc-z mint for 1600$ you can work him down. plus the carbs are down on pwer a bit to
Old Sep 17, 2003 | 09:38 PM
So you think it's def. the fuel pump? how easy would itr be to replace? It's a mechanical pump so its right on the block.
Old Sep 17, 2003 | 09:47 PM
DarthIROC's Avatar
If its a mechanical pump, its cake. But I would not say thats definetely what it is. Althought it is a prime cadidate.
Old Sep 17, 2003 | 09:52 PM
darth is right but look into it if its clean buy it check for overheating and oil leaks and check for underbody conditions to
Old Sep 17, 2003 | 09:54 PM
my fault i forgot you couldnt start it. just if its a clean iroc and looks like it was taken care of buy it
Old Sep 17, 2003 | 09:56 PM
thats a miracoulous beautiful camaro buy it most def youd be a fool if you didnt. you do know it has been painted once. youll need iroc graphics. but def go for it defientially
Matt Dreessen
Sep 9, 2015 09:58 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
Pestilence
Aug 18, 2015 06:19 PM
