Torsen?
Old Sep 15, 2003 | 11:03 AM
85_LG4
Guest
Posts: n/a
Torsen?
Is Torsen a good brand?
What is this I hear of a Torsen T2R rearend(or whatever the hell it is)?
What kind of Torsen could I get, but will fit into my stock rearend? I don't want a all new rearend, just insides? I am lookin at preferably 3:55's, and Posi..
Thanx a bunch,
Matt
Old Sep 15, 2003 | 03:18 PM
Marc 85Z28's Avatar
The Zexel-Torsen differential is a strong reliable unit. Strong enough and reliable enough that GM put them in most LS1 cars. They have no clutches to burn out so they last longer than the older clutch style differentials.
You can either contact Torsen about the differential for your 7.5" 10 bolt with 26 spline axles - expect to pay a good bit! Or since you already plan a gear swap too, SLP sells the differentials for $99. The only catch is you will need 28 spline axles, which can be found in some 89 cars and all 90-92 cars.
3.55 gears are not available for our rears. The closest you can come is either 3.42 or 3.73, with 3.42 being the better choice for a daily driver. You will need the gears for a 3 series carrier if you plan on going with the SLP "takeoff" Torsen unit.
Old Sep 15, 2003 | 09:38 PM
85_LG4
Guest
Posts: n/a
Ok.. first off, can you explain what exactly a "spline" is? Hear about them all the time.. but what the hell are they?
Ok.. so lemme get this straight.. SLP (a web-addy, please?) sells my diff. for about 100-bucks..
How much for the 28 spline axles from a used vehicle?
What the hell ya mean "change gears"? How much will they be? where can I get them?
Thanx man,
Matt
Old Sep 16, 2003 | 05:11 AM
axoid's Avatar
SLP is @ www.slponline.com
The diff that SLP sells for $100 is the T2 not the T2-R. It is still a good diff, but the T2-R has a larger side-to-side bias and won't free wheel like an open diff if you lift one tire or the other. The T2 if just fine it you not going to autocross or run road courses.
Old Sep 16, 2003 | 11:02 AM
85_LG4
Guest
Posts: n/a
Ok, so a 3:42 posi rearend from SLP is 100 bucks?
Plus I have to get a 28 spline axle?
Plus.. when I get done with the Camaro, I am lookin at about 300-350 hp.. will this diff. be good enough?
Matt
Old Sep 16, 2003 | 11:12 AM
85_LG4
Guest
Posts: n/a
Ya.. I just checked out the slp web-site.. what gears does it come with? Is it posi or no?
How much for a 28-spliner?
What else is gonna have to be changed in order to accomodate my new rear?
Matt
Old Sep 17, 2003 | 08:41 AM
axoid's Avatar
The diff is $100, gears are not included
3.42 gears are ~$200
28 spline axle shafts $???
Installation $???
The Zexel-Torsen differential is a limited slip differential. The terms "limited slip differential" and "posi" are interchangable.
Old Sep 17, 2003 | 11:10 AM
85_LG4
Guest
Posts: n/a
O.. sweet.. so it is a posi..?
Where can I get the 3:42 gears for 200-bucks from??
Matt
Old Sep 18, 2003 | 07:56 AM
axoid's Avatar
http://www.jegs.com/cgi-bin/ncommerc...61&prmenbr=361
Old Sep 18, 2003 | 11:04 AM
85_LG4
Guest
Posts: n/a
Ok, thanx man! Is this a posi setup, though?
Is Posi a high-priority if I have about 300-350 hp?
Matt
Old Sep 24, 2003 | 05:18 PM
Marc 85Z28's Avatar
YES! The Torsen is a positraction unit.
Posi is not needed for that kind of power, but without it you'll go nowhere One wheel peel sucks
Old Sep 24, 2003 | 05:35 PM
unvc92camarors's Avatar
hey, i might be selling my t2 torsen soon
still in box- i was going to use it on my v6, but if i end up gettin a z28, i think i'll sell it
i would probably ask for a 100$ shipped
let me know if you're interested
Old Sep 24, 2003 | 08:32 PM
85_LG4
Guest
Posts: n/a
Thanx everyone!
Hey unvc92camarors.. sent you a p/m.. check them out.
Matt
Old Sep 24, 2003 | 08:33 PM
85_LG4
Guest
Posts: n/a
Better yet.. check your email..
My name is Matt Mueller.. and I am from yahoo.com
Matt
badapple
Jan 11, 2004 08:12 AM
350350
Dec 5, 2003 06:02 PM
jcornss
Aug 8, 2003 10:27 PM
brannan_john
May 20, 2003 02:17 PM
y5e06
Apr 3, 2003 10:45 AM
