fans not coming on?
Old Sep 7, 2003 | 11:10 AM
IROC350's Avatar
fans not coming on?
i just got my tranny and shifter hooked up in the car, but when i start it the fans won't kick on...AT ALL! the car got to 250 degrees yesterday while a friend and i tested the tranny. i can't find the problem, any ideas?
Old Sep 7, 2003 | 12:02 PM
Pro
Guest
Posts: n/a
What all have you checked regarding the fans?
Old Sep 7, 2003 | 12:09 PM
Shaun 90 Iroc's Avatar
The fans won't kick on unless the car goes above a certain temp. The second fan will come on with the A/C though. To test if all the connections and fan motors are good. You can connect the top right two of the ALDL, i gotta special little piece, but i have used a paperclip to do that. Once the car is just in start mode.. but not started. Both fans should kick on. You will beable to see if one or both are not working or malfunctioning. My car started gettting hotter than usual and i did this and my primary fan would try and start and made some not so good sounds and just kinda died off.. So i went to GM and they just wanted $30-40 for a new fan motor. It could also be the relays though, which depending on the year can be located in different spots.
Old Sep 7, 2003 | 12:13 PM
lordmetalz28's Avatar
best thing to do first would be process of elimination. check your fusible link. next jump your fan straight to the battery see if it works at all. then you can proceed with you relays so on so forth and temp sensor.
Old Sep 7, 2003 | 01:58 PM
IROC350's Avatar
well, code 15 is being set off which deals with the temp. sending unit. the fans wouldn't cut on at all. the engine got to above 250 degrees and still nothing. there's not a wire going into the temp. sending unit and i think that may be it. but i cant find the wire...
Old Sep 7, 2003 | 02:02 PM
IROC350's Avatar
where does the wire originate from?? that may help in my search
Old Sep 7, 2003 | 03:16 PM
IROC350's Avatar
there was a blown fuse!!! problem is solved and after a year, the IROC is back on the road!
YEEHAWWW
Old Sep 7, 2003 | 08:24 PM
i know i just didnt see a post on radiator fans by pro lets not start again pro you got cut down bad last time because you have no idea what your doing. way to go with the fuse good luck with your car
Magenta_Hearts
Mar 29, 2017 08:54 PM
linz
Apr 7, 2015 11:49 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
