Im out of ideas...please help...runs rough/engine backfire
Old Sep 13, 2003 | 01:24 PM
saiyanrage's Avatar
1989 rs w/ lo3
I hate to write a book but its been a rough few months and Im going to try to mention everything in case it adds up to anyone.
First to radiator blew.14 years of crud decided to break looseLuckily I was pulling into my driveway when it went.I replaced the rad and while I was at it replaced the thermostat w/ a 180 degree one.
About the same time I noticed the tach would jump a little as I cruise.Occasionally you could feel the surge too.Thinking it was bad gas I added a fuel treatment.It worked for a few days then started surging again.A tune up was done.The plugs were changed to rapidfires and the distributor and rotor changed to MSD. Again it ran better a day or two then started surging again.
One day at a light it felt reeeeally rough.As I started moving I heard a "pow" from under the hood that sounded like a BB gun.When I got home I checked it out and found a vacuum cap had come off(shot off?).I replaced it but the car still ran rough.Its gradually become worse to the point I can feel it get rough and "drag"(kinda like when you drive through deep water"and then it will let off a massive backfire from under the hood.It will do this 3-4 time between home and work(about15 miles).
Ive checked the aldl and had a code 32(egr).I replaced the EGR and noticed the same vacuum cap from before was off again.This time I dabbed silicone on the hose first(come off now!!! )Anyway even with the new EGR when I test drove it I still ran rough and backfired. And yes,i disconnected the battery to reset the comp.
Any ideas?I hope to have it running for the F-body gathering in Bowling Green next weekend
Old Sep 13, 2003 | 04:07 PM
Brit Iroc's Avatar
Have you checked your timing since the new dizzy was put in?
Old Sep 14, 2003 | 03:27 PM
saiyanrage's Avatar
Ive messed with it more and this is what I found...
1)I was running rich because of a bad MAP sensor.For some reason it never blew a code
2)My timing WAS off...bad news is my 14 yr old timing chain is about kaput.Good news is while Im in da hood I'm doing the lt1 cam swap!
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Dzmaro
Jun 19, 2015 11:38 AM
Chet1185
May 10, 2015 09:24 AM
