need help car wont stay running!
Old Sep 2, 2003 | 05:46 PM
irocz8957's Avatar
hey guys i just got back from vacation i started my car up yesterday and it was running fine, the only thing i noticed was that when you reved it up it would quit running after the rpms dropped, so this morning i came out and tried to start it, and once you get it started it wont stay running unless you keep holding the gas pedal! anybody have any idea what this could possibly be please any help would be great!
Old Sep 2, 2003 | 07:59 PM
Rice Killer87's Avatar
sounds like an EGR valve is clogged/bad to me.
Old Sep 2, 2003 | 08:39 PM
87DJP2001's Avatar
Check for vacuum leak.
Old Sep 2, 2003 | 08:56 PM
Irocing's Avatar
Re: need help car wont stay running!
The same thing happened to my 87 IROC, does the car run fine until it gets warm? Mine would run fine until it got warm then it would just stall, I took apart the IAC(idle air control) and cleaned it really good, right after this the problem stoped, that is what i would recommend doing, clean the IAC and see if that works, keep us updated, hope this takes care of the problem!!!!!!
Old Sep 2, 2003 | 09:47 PM
irocz8957's Avatar
thanks guys im going out to clean my IAC vavle right now i'll keep ya guys posted, thanks again!
Old Sep 3, 2003 | 11:35 AM
IROC350's Avatar
my car does the same thing. be sure to post back on here with what you find...
Old Sep 3, 2003 | 06:33 PM
Kuruption562's Avatar
Where Is The IAC?
Old Sep 3, 2003 | 08:38 PM
bottom of the TB. take off all the intake stuff and the MAF and the rubber piece that clamps onto the TB (if its TPI) there are 2 holes on the bottom that lead to the IAC.
TB=Throttle Body
Old Sep 5, 2003 | 03:55 PM
Irocing's Avatar
Just checking up to see if u figured out what the problem was yet? Keep us informed if u could!!!!!!!!!!!!
cmdeshon
Dec 27, 2014 10:06 AM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
F(ast)-body
Feb 26, 2003 09:05 AM
supercharged94Z28
Feb 24, 2003 10:22 PM
