Shift Kit?
Old Sep 1, 2003 | 10:14 PM
Kuruption562's Avatar
Shift Kit?
Am I Supposed to DriVe It In D all the time or am I supposed to actually shift it?
Cuz when i drive it in D it be trippin it revs real high before switchin to 2nd probably up to 5500 when its hot, but when i shift it it runs way better, let me know what im suppposed to be doin... THANKS
Old Sep 1, 2003 | 10:40 PM
doug791's Avatar
you can upshift if you want i do for racing because i have an aftermarket shifter but DO NOT downshift it wrecks the transmission. If you car is shifting at 5500 at part throttle then something went wrong when they installed the kit....the only difference you should notice is it shifts a lot harder
Old Sep 1, 2003 | 10:55 PM
ThirdgenTa's Avatar
Make sure you adjusted the throttle cable properly. If not then it is only shifting at line pressure. Which could be a bad thing.
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
RedLineRev
Jan 23, 2003 03:51 PM
TrouserSnake
Aug 7, 2002 12:43 PM
