tranny acting funny? not completly sure...
When im in drive the car will happily idle at 750-850 rpms but when i throw it into neutral/park it pulls up to around 1500 rpms??? Is this normal or is something messed up
well it made sense to me that with an auto its kind of in gear when in D so itd rev lower then when its spinning freely. Just noticed how high it was in park though seemed a little high but i think shes okay.
Here is a theory. When you go to park, you engage reverse and it bogs the engine down. The IAC opens up and tries to keep the idle at the set point that the ECM demands. When you go into park, the load is off and the IAC should close but doesn't and so it keeps the idle high. I would take off the TB, IAC and clean them both, readjust the IAC and then the TPS (in that order) and see what happens. I don't get that sort of thing tho.
carguyshu
Jan 22, 2017 11:19 AM
