ground on Aluminum heads?..stupid ?
the grounding straps that connect to the back of the stock cast iron heads...will they still be grounded once I connect them to my aluminum heads? ..or do I have to find somewhere else to ground them?
its probably a stupid question and I guess I could ask someone at work.
thanks!
thanks!
Re: ground on Aluminum heads?..stupid ?
thanks!
thanks!
Aluminum is a good conductor of electricity, so yes bolt it back to the heads as stated, BUT make sure to use a STAR washer(not a lock) so your connection stays tight.
Brandon Wittmer
Dec 7, 2014 12:15 PM
