Delay on crank
Old Aug 2, 2006 | 12:29 PM
michaelxx16's Avatar
Question Delay on crank
when i turn the key to crank it, theres a delay like its having trouble starting up, ive changed the distrubitor cap and rotor, the center plug on the cap was corroded along with the spark plug wire it was connected to, i replaced the spark plug wire but still having the same problem. for the ignition the only aftermarket parts that are installed is a MSD 6A, anyone have any clue if the MSD box might have went bad in the past 3-4 years? or what the problem might be?
Old Aug 2, 2006 | 02:00 PM
WS Sick's Avatar
Re: Delay on crank
I'd bypass the MSD and see if it fires better. Look over the connections to it to ensure they arent corroded as well.
Old Aug 2, 2006 | 02:30 PM
Re: Delay on crank
How do I bypass the msd box? Just unplug it?
Old Aug 2, 2006 | 03:49 PM
WS Sick's Avatar
Re: Delay on crank
If you have the dual plug external coil you can just unplug the pigtail and plug the factory harness back onto the coil
If you have the coil on top HEI, then you'll have to mark your wires from the MSD and put the factory wires back to their original spots on the dist.
Jeff1904
Jun 5, 2016 05:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
