Building a v8 Small block
Old Nov 27, 2006 | 08:50 PM
crusher135's Avatar
Well pretty soon im going to start building a v8 small block, i want around 650-700 horsepower, where would i start? i know its alot of money but i dont want it supercharged or turbo'd i will put NoS on it, so its going to have to be strong, i want 650-700 horsepower without the nos, where do i start? help me out :P
Old Nov 28, 2006 | 07:56 PM
respectirocz's Avatar
you've got high hopes
nothing wrong with ambition
start with a budget and get the most horsepower around the budget
do searches, u'll wont a 4 bolt main block, you need to decide on a cam and heads that will work well with nitrous
the search button helps alot
Old Nov 28, 2006 | 08:09 PM
crusher135's Avatar
i will be going with a strocker, 383 baby, and ill get 650 hp for 10 g's flat, my buddys dad is an engine builder just found this out, and he has built a few and they are mint engines
Old Nov 28, 2006 | 08:19 PM
Marc 85Z28's Avatar
Care to post some specs? Getting 650-700HP out of a 383" engine naturally aspirated would require an EXTREMELY RADICAL setup, RPMs north of 8000, and would most likely cost more than 10 Gs... Most competent big name engine builders need 70 more cubes to attain those power levels.
Old Nov 28, 2006 | 09:09 PM
AutoRoc's Avatar
Here's a link to a proven 668hp/550lb-ft 406 cube engine buildup. Monty is a local Michigan racer and this was one of his first engines that he ran 9.80's on motor and 9.11's on a 250 shot in a 2nd gen Z28. It's pretty much off the shelf stuff.
http://www.yellowbullet.com/forum/showthread.php?t=548
Old Nov 28, 2006 | 09:55 PM
crusher135's Avatar
ill post some specs when i start building the engine, im building up my car first
Old Nov 29, 2006 | 06:11 AM
Marc 85Z28's Avatar
I didn't say it couldn't be done. And that engine is 20 cubes larger (bigger bore helps with HP numbers), 14:1 compression, LARGE solid roller cam, and topped with a Dominator - pretty much like I said.
Old Nov 29, 2006 | 12:20 PM
BlackRabbitZ28's Avatar
No offense but its not going to happen. Sure its very possible but if you need to ask people where to start on your engine build and you want that much power NA then theres the first problem.
Old Nov 29, 2006 | 03:29 PM
Speed Demon 505's Avatar
Yeah I agree to the guys on this one, 700hp is damn hard to make w/o a power adder.
Shouldent be very hard to tap that number with NOS though. Maybe you want something solid that you can spay the heck out of? Forged bottom end, 4 bolt. Then some good heads like AFRs and a fogger and whalaa!
The absolute best advise I think anyone can get for ANY build is PLAN WHAT YOU WANT FIRST! Oh yeah thats the ticket right there. At the same time you have to have the disipline to stick to the build too. It always seems easy to just buy a bigger cam or a little different manifold.
Try this:
Eagle rotating assy-$1900
Dart block-$1800
AFR Eliminators-$1400
Intake and Carb-$650
Cam and lifters-$300
Headers-$300+
Distributor-$250
Coil and Wires-$80
MSD Box-$300
Nitrous system-$500
Gaskets-$250
Oil system-$250
Studs-$200
Machine work-$300
So at the end of it all your looking at $8500 just to get started in the engine!
Also I recomend you save the money first, it sucks bad to have half an engine built and no money to finish it. Also you dont know if you may have an emergency that requires some cash and if your spending all your dough on parts every payday your probably broke and will have to take a hit by selling some parts.
Old Nov 29, 2006 | 05:26 PM
AutoRoc's Avatar
505 forgot to mention that you should double your budget before you start just to save a couple headaches and actually finish by the time you want to finish.
And nobody mentioned calling Shaffirof and ordering an engine. http://www.ultrastreet.net/ Pick and choose, pay and recieve.
Old Nov 29, 2006 | 11:24 PM
crusher135's Avatar
seriouslly do u guys know what your talking about? im sure you do, but guess, wat, you can make a 900 hp engine, for 15 g's i can make a 650 hp engine for 10, and ill proove it to u in a year, after i finish upgrading my car, and start the engine, my buddy has a 6 second car, i forget wat kind of car it is but it has 1500 hp, in a ****ing smallblock, he said he got to 900 hp with 15'gs watever stop dissing me, i can make a 650 hp engine for 10 g's and trust me in a year u will see me posting here with all the specs and photocopies of the receipts
Old Nov 30, 2006 | 03:27 PM
2000GTP's Avatar
It is by all means possible to do that kind of buildup and achieve those power goals. However, as mentioned above, you will sacrifice just about any street manners that the car will have. If you are okay with having a car that is mainly for track duty, then by all means go for it. If you want something more tame, then I would build a mild heads/cam motor and try to squeeze out 450-500hp and throw a decent amount of nitrous on top of that.
Old Nov 30, 2006 | 04:17 PM
AutoRoc's Avatar
This entire thread doesn't make sense from the start because he's not letting anyone know WHY he wants however much power. You have some people screaming IMPOSSIBLE, others are saying you can do this and that but it's probably best if crusher135 did some searches to gain info on what an SBC is because he does not know where a good place to start is.
We all know 15 grand can have 1000hp delivered to your door, in many forms of engine and sometimes even with a damn warranty.
Oh, and if you can make the amount of power that you need, why are you asking how to do it? There are easier ways to start a conversation online. You can type stuff such as: "What's the best catback", "What's better, Ford or Chevy?", "Cereal rules, but why?"
Old Nov 30, 2006 | 05:54 PM
Marc 85Z28's Avatar
He's not making that kind of power naturally aspirated, like you stated was a requirement for your engine. Why not ask him to build you a 900HP naturally aspirated SBC?
Old Nov 30, 2006 | 08:47 PM
crusher135's Avatar
cause thats 15 g's and i only want to spend 10-11 on the engine itself, more money is going into the car
