Where do the rods that run down the column to the ignition switch go?
Old Aug 29, 2006 | 09:01 AM
'86 350's Avatar
I replaced the ignition switch on my car, and now I'm stuck on where the 2 rods that run down the column go. I know they either connect to the ignition switch or have something to do with it, but I'm not exactly sure where they go. I checked in my Hayes manual and nothing was there on it, so I'm asking you guys. If anyone could give me an idea of what they connect to or where they go that'd be great, I wanna get this back together and running again.
-Thanks, Brandon
Old Aug 29, 2006 | 02:10 PM
Camaro_Boy's Avatar
Re: Where do the rods that run down the column to the ignition switch go?
hey buddy, i i think what you are talking about is the high beam switch.. it goes to the bottom of the steariing shft.. there is a kinda button thing there.. sorry.. i dont know how to explain it.. its basically a switch to activate your high beams.. as for the other im not sure if i ever had one... best regards
Douglas
Old Aug 29, 2006 | 02:46 PM
Zepher's Avatar
One rod is the ignition switch and the other is the high beam switch.
Old Aug 31, 2006 | 05:01 PM
Wilhelmz28's Avatar
just got finished with my ignition switch, when u turn the key that rod pull back on the ignigiton......... switch the other the brights
big tip here wasted an hour on trying to get the bright switch working. Tilt the wheel all the way down once u hav the ign... switch in the right spot place the rod on the back of light switch and release the tilt slowly
are u having a random starting problem ?
DirtyDaveW
Dec 1, 2016 05:37 PM
Hurin
Dec 13, 2014 07:38 PM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
