Does anyone have True Dual Exhaust on thier 3rd gen?
Old Aug 12, 2006 | 12:35 AM
86irockz28's Avatar
I was wondering if anyone has true dual exhaust. and if so, does it rub at all? I want to put true duals on my camaro and get rid of that y-pipe. Does anyone know where i can get some pipes?
Old Aug 12, 2006 | 09:08 AM
89Vert's Avatar
Re: Does anyone have True Dual Exhaust on thier 3rd gen?
true dual on a 3rd gen has and can be done,
very rarely have I seen it dorn well,
one of the only ones I've ever liked is on a friend of mines car and its rarely street driven, cause the exhaust goes under the axle instead of above it, and he is dual full 3"
your better off to run a single full 3" mandrel bent
Old Aug 12, 2006 | 09:27 AM
Willie's Avatar
I guess you haven't seen our website before:
http://www.thirdgen.org/techboard/ex...l-exhaust.html
The link to my exhaust webpage is in Reply #2.
Old Aug 12, 2006 | 09:34 AM
86irockz28's Avatar
I like that Setup a lot. Looks like it works good, how does it sound? Do you have problems with it rubbing even though it follows the same lines as the stock exhaust?
Old Aug 12, 2006 | 09:40 AM
Willie's Avatar
Thanks. I was the first to come up with this design. How does it sound? Well, take a listen to this "puny" 305>> Click on the appropriate link here:
http://www.iroc-zpostforum.com/MemberWillie.htm
None at all. And the same ground clearance as the stock exhaust too.
Willie
Old Aug 12, 2006 | 12:18 PM
Fire's Avatar
Damn, thats a beautiful exhaust willie, ive also been looking into how something like that might be done for a 3rd gen...
Old Aug 13, 2006 | 01:04 AM
89Vert's Avatar
yours is one of few I like, I have pics of it saved on my computer
almost all of the other 1's posted in that link look terrible
Old Aug 13, 2006 | 09:51 AM
bowtiepastya's Avatar
I have hooker long tubes with 3" collectors. took it up to a local muffler shop and they welded up 3" to 2.5" collectors, true dual dumps right before the rear end with glasspacks. not too street legal but it performes and sounds great.
Old Aug 15, 2006 | 09:12 PM
elementaltoad's Avatar
I have true dual sidepipes on mine, doesn't even rub speedbumps - i love the look and sound of it.
Dual 2.5" side exit/dual tip
Angled
Dual bullet mufflers
Old Aug 15, 2006 | 09:15 PM
BY the way, That entire setup only cost me $290 - and its still street legal as i have a 1989 Fomula 350 with the Dual cat option - cant beat it. I'm not even sure anyone else around me let alone texas has a daily driver with that setup...
Old Aug 17, 2006 | 02:14 AM
86irockz28's Avatar
is that custom or did you find a kit somewhere?
Old Aug 17, 2006 | 11:29 AM
Mr. Wolf's Avatar
how come you didn't dump out in front of the axle cause thats legal in Texas to do that?
Old Aug 23, 2006 | 08:48 PM
It is custom, I didnt dump them because i wanted a nice look and a reasonable sound - I've done dumps and they are just too loud. But any competent shop should be able to bend and weld with any luck and reproduce what you see. There is no substitute and it is very cheap and flows very well...mine are mandrel bent, i wouldnt waste more money on a kit for a single/dual rear exit. See many fuel injected cars with sidepipes?
Old Aug 23, 2006 | 09:02 PM
twistedwedge's Avatar
Willie-your exhaust looks really nice. You did a fine job. IMO Perfect choice for a mildly modded street/strip car.
True duals will really wake any car up that has a lot of work done to the engine (with the exception of a turbo car). Ive seen it in several f-bodies, and really noticed it at the track on mine. The stock design is about the worst configuration you can get.
The only reason I didnt do all those crazy bends in my duals when I had the car was mainly it robs power when you route it everywhere and I had 3 inch pipes also. The more turns your exhaust makes, the harder the motor fights to get the gases out. But my car was mainly a true street/drag car, I was all about getting the most hp and love the sound of duals without tailpipes. Wish I could find some pics to show you, the lowest point of my exhaust was where the full length tubes met the exhaust pipes, and it rarely scraped. The car was pretty low to the ground as well..
Old Aug 25, 2006 | 02:41 PM
its illegal to dump it out anywhere under the car where i live but i know a couple of inspectors. i just went to a local muffler shop and the guy there welded it up for me. he said it was illegal to do so withour cats so i just gave him a good tip.
