350 Crankshaft In A 305
Old Nov 12, 2006 | 08:55 PM
86z28nos's Avatar
ok ive got a 87 305 roller motor that iam rebuilding and i wont to use a 87 350 crankshaft because it is enternal balanced i know thay both have the same storke so are thay the same thanks for your help
Old Nov 12, 2006 | 09:57 PM
89TramsAmGTA's Avatar
They are both the same "almost". The 350 has heavier counter weights so you would have to have them cut down or drilled to be balanced correctly.
FWIW a lot of the guys here locally use 305 cranks in their 350's. With light aftermarket pistons and rods it is easier to balance with a 305 crank. With a 350 you have to remove a lot more material for the balance.
HAWG
Sep 25, 2015 11:41 AM
Tarizza
Sep 20, 2015 03:26 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
