AFR head and ARP head bolts?
Old Oct 16, 2006 | 08:47 PM
Wishmaster's Avatar
do I want 6 point or 12 point head bolts to go with my AFR heads?..Ive read something about certain type bolts not giving enough clearance with certain type rockers? Im using comp pro magnums if that helps.
thanks
Old Oct 17, 2006 | 10:45 AM
Z28SORR's Avatar
Re: AFR head and ARP head bolts?
I think you'll be happier with the 12 point.
Old Oct 17, 2006 | 11:59 AM
Wishmaster's Avatar
I went ahead and got 6 points...gottem for 30 buck new....whats the big difference anyways? more points to get a socket on? I mean the bolts cant be that different, ey?
Old Oct 17, 2006 | 12:11 PM
Damon's Avatar
If they are the SMALLER 6-point heads (take 1/2" socket) you will be fine. There are several head bolts you just can't get a full sized 5/8" socket on (like stock head bolts take) without removing a valve spring.
ARP bolts also come with the anti-galling washers, so you need to use them with aluminum heads. The side with the beveled edge on the inside goes UP towards the head of the bolt.
Old Oct 20, 2006 | 04:00 PM
YenkoST's Avatar
You can get to them with a 5/8" socket...just got to grind it down a bit. Mine works very well.
Old Oct 20, 2006 | 07:52 PM
Wishmaster's Avatar
I checked and yeah, I can get a 1/2 socket on them...they got the small head...smaller than the ARP head studs I had... thanks!
Old Oct 22, 2006 | 04:25 PM
krazzycowgirl's Avatar
which AFR heads did you go with?
I have the 195CC for my Iroc
Old Oct 22, 2006 | 09:16 PM
Wishmaster's Avatar
I went with the new 195 eliminator 65cc's ..I still have not received them and I ordered them back in July.
Old Oct 22, 2006 | 09:18 PM
ws6transam's Avatar
That's what I did: I bought a deepwell socket, then tapered it with the bench grinder. It works like a charm.
Old Oct 22, 2006 | 09:22 PM
who did you order them from?
most of the time they are back ordered up to 6months. I got mine via AMP Performance which is a mustang place but they also sell AFR heads. Got them for a great deal & they had some in stock.
ampperformance (their Ebay name)
Old Oct 24, 2006 | 08:33 AM
Wishmaster's Avatar
I ordered straight from AFR
Old Oct 24, 2006 | 09:27 AM
Then they are going to take a while longer
MattFick
Feb 15, 2015 10:16 PM
pimpss96
Feb 12, 2015 01:28 PM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
Wilson
Jul 21, 2002 05:08 PM
