need a balancer for my 383 which one? FLUIDAMPR?
Old Aug 9, 2006 | 11:43 PM
Wishmaster's Avatar
I want to get an aftermarket balancer for my 383..its internally balanced and had a 6.75 stock balancer on it...
I was told I could get any aftermaket and any size as long as it was for a internally balanced motor...
will a FLUIDAMPR 7 1/4 work? or not? or does it have to be 6 3/4 or 8"
can someone point me in the right direction..link? so I can buy one
Old Aug 10, 2006 | 01:00 AM
1987IROC350's Avatar
Re: need a balancer for my 383 which one? FLUIDAMPR?
This link might help. I selected 5.7 ltr 87 Chevy Camaro. When you select one click on :Check to make sure this part fits your application!!http://store.summitracing.com/egnsea...115+4294840140
Old Aug 10, 2006 | 07:42 AM
Wishmaster's Avatar
none of the balancers specify for a 383.....what do I look for? do I want one for a 350 or a 400? please someone help...thanks
Old Aug 10, 2006 | 09:05 AM
I spoke with Tim at Summitracing, free tech line #(330)630-0240, and he asked what crank you used. I didn't know, but he said usually 383 use an enternal balance. I told him you said it was internal. He said if that is true you can use any that would fit a 5.7 350. But I would call them. They really are nice to deal with. Please post the solution. Good luck. Is the 383 in your Camaro or something else?
Old Aug 10, 2006 | 05:12 PM
Wishmaster's Avatar
Yeah I called FLUIDAMPR and asked them about it and they told me the same thing..that if it is internally balanced that any neutral balanced dampner would work, so Im going to gt one of theirs.....thanks for all the help....
yeah the 383 is going in my car, its on the engine stand right now waiting on my heads to get here from AFR and for me to pick a cam out so I can finish it up...I still gotta get my old 305 outta the car...but I have it atleast tore down to the short block...
Old Aug 11, 2006 | 08:06 AM
Cool. Good luck with getting it all together. I know the down time sucks. My car is in the shop getting all the stuff in my sig. installed.
Old Aug 11, 2006 | 03:07 PM
ws6transam's Avatar
You can save a significant amount of money by purchasing a viscous damper with SFI rating. I purchased and installed a Pioneer brand damper on my 385 stroker based on recommendations from SCAT engineers, who prefer standard dampers.
I have a 6.25 inch, Pioneer harmonic balancer, part number 2021, I believe. It's SFI approved and quite light which is good for revability! I bought it back in 2001 for about $120 or so.
Here's the damper at Summit.
Jeff1904
Jun 5, 2016 05:00 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
