HELP WHIT remote mount turbo system IN MY TIRD GEN
Old Aug 16, 2006 | 09:20 PM
90iroccrazy's Avatar
all you guys are reallly good at this turbo stuff and lets just say im noT. Well i have a 90 iroc-z convertible and want to do the rear mounted turbo set. the iroc has a 305 motor that im going to change to a l98. is there any turbo that i can use on a 305 but still work good whit a 350 and if there is not what caind of turbo is good for a 305 and what turbo is good for a 350 everything els i think i got it i have read all the post and they help. and one more question the turbo use oil from the oil pan so you tap in to the oil pan and connect it to the turbo thats it rigth then to punp the oil back we use a oil pump. pleas i need help thank im clueless
Old Aug 17, 2006 | 11:41 AM
Pneumatic_Tire's Avatar
Re: HELP WHIT remote mount turbo system IN MY TIRD GEN
Please, leave the slang in the hood.
Old Aug 18, 2006 | 04:37 PM
AutoRoc's Avatar
This forum is turbo lacking Check out LS1tech.com's Forced Induction forum for more ideas and pics from installs both with STS and custom made. A turbo with an inlet of 62mm-76mm is common for the LT1-LS1 STS kits so they would also work with a 350cube TPI setup. Turbo side and piping size will depend on expected power output. For a stock TPI 305/350, I'd use a 60-65mm turbo, roughly 8PSI of intercooled boost and call it a day...
I don't like the pan tapping method myself. I'd use the small 1/4" oil plug on the front of the engine or the oil pressure sensor hold near the filter. it'll pump it to the turbo, then run another pump to return the oil. Some guys use a remote mount oiling system as well. It's a small tank/pump in the rear that is for just the turbo itself. I don't have any experience but this is what I'm reading and seeing around the net.
Old Aug 20, 2006 | 11:18 AM
thank you autorock thats what i was thinking whit the filter to thaks for the info
Old Aug 20, 2006 | 05:41 PM
Willie's Avatar
I saw my first STS kit on a Camaro last weekend. It was an '02 SS. I may be showing my ignorance here but I was not impressed. First, the turbo hung so low that any speed bump would take it out. In fact, I saw the car at a muffler shop who's job was to see if the turbo could be raised. After they were done, it had about four inches of clearance. I wonder how much it had with the pre-made STS pipes.....
Also and of particular interest was the fact that this turbo had no oil lines.... Is this weird or am I missing something?
I also noted that the piping at the turbo outlet necked down to less than a two-inch diameter, then expanded to over two-inches (I think).
The turbo itself looked rusted and the exposed conical air filter was filthy, probably because of location.
My overall impression was not good. I walked away thinking this thing is a piece of junk. I'm very glad I went the traditional way and mounted both my turbos in the engine compartment....
Old Aug 26, 2006 | 07:40 PM
what caind of turbo sud i put on?
DirtyDaveW
Dec 1, 2016 05:37 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Jeff1904
Jan 3, 2015 12:00 AM
Jul 4, 2005 05:00 PM
Absolute Z28
Jul 19, 2002 02:21 PM
