Tune up
Old Nov 28, 2006 | 01:53 PM
Robert Martellacci's Avatar
Tune up
Hi Guys,
Need some info.looking to tune up my 1992 Z28. It has original wires.(16000 miles) Should I go with GM wires or aftermarket.Help me
Thanks in advance
Old Nov 28, 2006 | 02:02 PM
xdamagedx's Avatar
Well, here's my opinion, and I'm by no means an expert: I say it depends on how "upgraded" your car is and what fits in your budget. If it's mostly stock and you're semi-money conscious: get GM replacements. If you've got a bunch of aftermarket goodies in it, you're probably trying to squeeze as much performance out of it as possible, and you've probably got more of a budget for your car then I'd reccommend a higher end wire.
Old Nov 28, 2006 | 02:45 PM
BlueZee28's Avatar
This is what I did when I did my tune-up:
Taylor 8mm wires $50-ish
AC Delco Platinum plugs $dont remember, check Autozone
GM throttle body/top engine cleaner $12-ish
Sea Foam (put it in the gas tank) $10-ish
MSD distributor cap $25
MSD Blaster GM coil $40-ish
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
