Will this engine work in my Camaro?
Old Oct 16, 2006 | 03:13 AM
94LT1Maro's Avatar
http://www.crateenginedepot.com/stor...6-P786C63.aspx
I need to know if I would have any problems putting one of these into the car. From what I can tell it's the same thing that's in it now just a model year newer. And if memory serves me right, nothing really changed on the TBI Motors. I've decided to do this b/c it's easy, and fairly affordable. Plus the warranty doesn't hurt either. Thanks Guys...
Old Oct 16, 2006 | 06:54 AM
teke184's Avatar
Re: Will this engine work in my Camaro?
since it's a different year, make sure and check to see if the warranty is still valid. sometimes they do some "fine print" on things like that.
if i were you i would ditch the 305 and upgrade to the Goodwrech 350 for a couple hunder more bucks.
linky
when the warranty is up...stab a bigger cam in there and you'll be making 250hp or so.
Old Oct 16, 2006 | 08:13 AM
thirdgenrallysport's Avatar
ewww... dont waste money on a 305... you will be much happier spending a bit more for a treefiddy.
Old Oct 16, 2006 | 10:34 AM
formul8's Avatar
You will spend more modding the 305 than it would be just to buy the 350 crate with more HP to begin with.
Old Oct 16, 2006 | 11:52 AM
94LT1Maro's Avatar
I realize that but I just need the car to run, i'm getting a divorce and well the Camaro is going to be my Daily Driver again. So I need something that I can just literally drop in and go. Something that doesn't need any major changes, although I will take this opportunity to install my Headers and Y-Pipe.
Old Oct 16, 2006 | 12:19 PM
ringo234's Avatar
The 350 is identicle in size and shape on the exterior, so it will bolt right up. You may need to upgrade the prom and injectors but that should be it.
Old Oct 16, 2006 | 12:32 PM
Ucantcme57's Avatar
I believe this is why he is wanting a drop in...
Some arguement can be made though if the 305 gets better gas mileage than the 350
Old Oct 16, 2006 | 02:13 PM
respectirocz's Avatar
was it 88 or 89 that they began full serpentine belt setup because i believe that would effect the type of balancer used
Old Oct 17, 2006 | 01:11 AM
1987IROC350's Avatar
I think this is the one you need. http://www.sdpc2000.com/catalog/123/...ate-Engine.htm
Old Oct 18, 2006 | 03:18 AM
94LT1Maro's Avatar
Looks like that one will do the job, although I may pay a little more, I at least know it won't void the warranty. How is your new TPI engine running? If I had more time I was going to drop that one in. It looked like a real hellraiser on paper. Ah well i'll hop this one up a little bit, and eventually work my way up. Thanks for your help guys I appreciate it.
Old Oct 18, 2006 | 08:35 AM
This one is really good, 330HP/380LB FT, also and still pretty cheap. You might have to use a different intake. http://www.sdpc2000.com/catalog/120/...e-Assembly.htm
nballisru
Dec 14, 2014 05:01 PM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
ChrisFrez
Nov 23, 2014 10:33 AM
Snoman73
Nov 17, 2014 07:22 PM
