Heads cc chamber size???????
Old Aug 17, 2006 | 03:53 PM
1987IROC350's Avatar
What is deal with chamber size? So many different ones to choose from. My Scoggin Dickey crate Vortec TPI motor has 64cc vs. the 58cc in the ZZ4 motor. So what does that mean?
Old Aug 17, 2006 | 09:19 PM
Z28SORR's Avatar
Re: Heads cc chamber size???????
"Cubic Centimeters" With the same piston, say a flat top, the smaller the combustion camber size, the higher the static compression will be.
For example with the 64cc cambers you might get 9.5 to 1 compression and with the 58cc you might get 10 or 10.5 to 1.
The cc is mesured by using one of these. http://store.summitracing.com/partde...5&autoview=sku
Old Aug 23, 2006 | 08:05 AM
TPI350IROC's Avatar
So the 58cc would perform better than his 64cc? The smaller cc the more HP and higher compression?
Old Aug 23, 2006 | 08:19 AM
teke184's Avatar
theoretically YES.
but you also have to take into account whether the higher compression will cause detonation or not.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
Mar 13, 2016 03:39 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
