starter the 350 for the first time...
Old Jul 29, 2006 | 12:11 PM
Camaro_Boy's Avatar
hey, finally got the starter all sorted out. now when i turn over the key the starter motor turns and the engine is spinning... but the electrical to the dash isn;t working and the motor is not turning on.. is this related?? from the starter motor which wires comes to the dash for power to the panel?? i look in the book.. no such luck.. 1986 camaro put in a new 350 motor its carbed..
Old Jul 29, 2006 | 12:20 PM
s10er8's Avatar
Re: starter the 350 for the first time...
what kind of distributor are you using? what type
also how did you wire up the distributor?
Old Jul 29, 2006 | 12:47 PM
Camaro_Boy's Avatar
ac delco - remy is what it has on it. its not a electronic distributor. would that cause the tach and all the gauges not to show??
thanks in advance
Old Jul 29, 2006 | 01:40 PM
s10er8's Avatar
no that wouldn't affect the gauges but you said it wouldn't start
I guess you know already but there's a wire somewhere that's not connected. Chevy put junctions on some firewalls that ran a hot wire to the fuse box, some hot wires come off of the alternator and some off of the starter. You are looking for a red wire that is not hooked up probably in the engine compartment somewhere.
www.autozone.com has wiring diagrams but you probably need to just look around for a few minutes to find the wire that's not hooked up
check all of your fuses also just to eliminate that as a possibility
Old Jul 29, 2006 | 02:38 PM
Camaro_Boy's Avatar
wow... i forgot the mention that when i was putting the starter in. 1 single wire from the positive was not attached... it wasn;t meant to be put back. i shorted out the starter underneather. im going to check the fuse right now.. THANKS soo much
regardless
Douglas
Old Jul 29, 2006 | 03:24 PM
Camaro_Boy's Avatar
ok perfect the starter and the gauges are now working.. the fuse was blown.. thanks!!
Formula Steve
Sep 19, 2023 08:31 AM
HAWG
Sep 25, 2015 11:41 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
