89 iroc z trans
Old Aug 22, 2006 | 12:56 AM
1quik69's Avatar
89 iroc z trans
We have just finished picking up my sons supercharged 383 that he is putting into a 72 z28. We have a 700r4 trans that came out of an 89 iroc sitting in the garage. How strong is this trans and how much hp can it take in modified condition? The dyno sheet showed 618 hp and an avg of 400+ lb/ft or torque. He would like to use an automatic as opposed to a manual if possible.
Old Aug 22, 2006 | 02:21 AM
davidarel's Avatar
Re: 89 iroc z trans
The 89 was the first year of the upgraded 700. I would definately spend the extra money and upgrade the reverse input drum (sun shell), the planetary set and put a shift kit in it. The trans will probably hold for a little while but it doesn't make sense to put it in and hope it will hold instead of starting fresh with upgraded internals. If you do it yourself you can save a small fortune. Don't be intimidated by it.
Old Aug 22, 2006 | 02:27 AM
89Vert's Avatar
Re: 89 iroc z trans
I know a guy running an 800hp when supercharged 383. backed by a built 700R4
he blew it up after 4000km, and he rarely ran it with the blower on it,
turbo 400 is the way to go
mark0006
Feb 28, 2015 07:12 PM
dale3in98
Feb 14, 2015 12:18 PM
capebuf
Jan 13, 2015 07:22 PM
rockync7
Jan 1, 2015 05:10 AM
