trouble with tpi start
Old Aug 15, 2006 | 11:00 AM
romans4l's Avatar
I recently purchased my 88 iroc. Last night I stopped at the gas station to fill up and when i tried to start it to leave, the motor died right out. I gave it a little gas a couple starts after and it started as long as I put constant pressure on the throttle. I ended up driving it home but I had to keep my foot on the gas the whole time. This morning I was trying to start it again and same thing. Could this be a bad sending unit? Please Help!!!! I love that car..
The only trouble code is 34.
Old Aug 15, 2006 | 12:23 PM
IROCThe5.7L's Avatar
Re: trouble with tpi start
34 is a MAF sensor code. Try replacing the MAF power and burnoff relay before you replace the MAF.
Old Aug 17, 2006 | 09:42 AM
romans4l's Avatar
Thank you
I changed the MAF but that didn't work. I reset the ecm to clear the codes and now a code 33 and 34 are popping up even after I changed the MAF. Could it need a new MAF power and burnoff relay? I'm thinking the fuel filter possibly but I have limited time to change it if it is so any advice helps!!!
Old Aug 18, 2006 | 01:24 AM
quickchicken's Avatar
check around for vac leaks. a vac line could have fallen off and injection is more sensitive to this than a carb. also when ya change a MAF iv heard its good practice to swap the 2 relays as well.
David Dorris
Jan 17, 2015 08:10 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
A's 91 Z28
Dec 7, 2014 12:09 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
