wiring help
Old Oct 23, 2006 | 10:32 AM
ryan77's Avatar
wiring help
hey all....I'm in the process of wiring up a 88 camaro that has had the old wiring harnes hacked up....I have a good harness out of a v6 car and the v8 harness is the one thats hacked up(by the previous owner)....the engine is a 305tbi....ok...so the part thats good on the hacked harness is....from the computer all the way to the wiper motor....all the sensors pluged up fine....heres the hacked part....where the harness goes in the firewall on the DRIVERS side...its cut off....with a battery in I have nuthing....so I'm figuring ign and all from the drivers side comes from that part of the harness....so...if I have most of the v8 harness already pluged to the engine...and just need to splice it to the existing v6 harness that enters the firewall on the DRIVERS side....will i be fine??? from what I gather...its just lights/washer pump/cruse control/ign...and such...coming from that location.....I have the 305tbi computer hooked to the other end...the end thats plugged into every engine sensor...does this make sence....does anyone know what the harness coming from the DRIVERS side wire wall go to?????
Old Oct 23, 2006 | 06:21 PM
oneslowz28's Avatar
Re: wiring help
if you look in my 3rd gen lt1 swap write up in my signature below this post. i have some scans posted of the c100 bulkhead wiring descriptions for the v6 and v8 . it should help you out some.
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
