86 305 not starting
Old Sep 29, 2006 | 12:21 AM
Fromaster's Avatar
86 305 not starting
curses. i had to leave my car at school cause it dident want to start, when i turn the key, nothing, not even one crank. battery is fine. me and my brother think it might be a loose connection on the starter because it starts sometimes but not all the times. anyone have this problem? im pushing it into the school mechanics shop tommorow, what should i look for? thanks.
Old Sep 29, 2006 | 10:30 AM
DCJLove's Avatar
Re: 86 305 not starting
Do you get juice to the electronics? Lights work, gauges, radio, etc.? If you have power, I'm sure the starter could be bad/have a flat spot.
I will also recommend checking your Reverse/Neutral safety switch if you have the auto trans. My switch went bad and when I replaced it, it didn't seat tightly in the mount so that the trans didn't "know" it was in P or N to allow the starter to crank. It appeared as an intermittent starting problem.
Old Sep 29, 2006 | 06:10 PM
angel71rs's Avatar
A way to test for this is to make a U out of a small piece of a large paper clip and use it to jump the connector terminals (use tape to insulate). If it starts then, neutral/safety switch is the problem. I did this once in the parking lot at work when my old 89 Formula wouldn't start to get me home.
Some manual cars also have a switch on the clutch pedal.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
markaubuchon
Jan 14, 2015 01:48 AM
Collector Car
Jan 5, 2015 10:58 AM
