Mini ram vs. Holley stealth ram
Old Aug 18, 2006 | 11:09 AM
1987IROC350's Avatar
http://www.tpis.com/index.php?module...niRam+Manifold or a Holley http://store.summitracing.com/partde...5&autoview=sku
Which is better to upgrade to for my crate engine http://www.sdpc2000.com/catalog/1578...rip-Engine.htm
Old Aug 18, 2006 | 03:00 PM
97WS6SCharged's Avatar
Re: Mini ram vs. Holley stealth ram
HSR is $525 + tax shipped to your door with fuel rails and regulator.
Miniram is $900.
I know why I went with Holley.
HLY-7542 is the one for Vortec heads.
http://store.summitracing.com/partde...0+0&rsview=sku
Old Aug 18, 2006 | 04:52 PM
Gord's Green Z28's Avatar
When did the Mini Ram change it's look? Used to be wider. It almost looks like a Ramjet now.
Old Aug 18, 2006 | 08:15 PM
Also I just realized there is an Accel Super Ram. Now which of the three is best? Super ram may need mods to work with Vortec though. Hey GORDS, look at the Accel, you might have thought it was the mini ram. http://store.summitracing.com/partde...5&autoview=sku
Old Aug 18, 2006 | 08:34 PM
Dave89IROC's Avatar
it looks wider when you put the fuel rail on
Old Aug 18, 2006 | 10:03 PM
grammerman's Avatar
Which of these intakes would be best depends entirely on what cam/head package you're running. To make the Miniram intake payoff you need a nice set of heads and a pretty large cam so you can spin to at least the 6500 to 7000 RPM range. On a large cammed motor with stock or near stock heads an LT1 intake conversion might work nearly as well for less money. If you combine either of these short runner intakes with a mild cam and heads you will be misusing it and the midrange/lowend and especially the throttle response will fall off compared to the two other intakes you mentioned. That is acceptable when you have the cam/heads to trade low/mid for topend but would be a mismatch on a mild street type motor.
The Stealth Ram runner length increases the engine's volumetric efficiency in the 4500 to 6500 RPM range so combined with a healthy but not super aggressive cam it will probably produce more peak power and a wider peak than the LT1/miniram intakes. You really need a hot cam to turn enough RPM's for the short runner LT1 or Miniram intakes to produce the best power. The Super Ram boosts the VE in the 3 to 5K range and works well with moderate cams that produce peak power at say 6K or below.
If you're at all concerned with throttle response or midrange power the Super Ram will work best there followed by the Stealth Ram with the Miniram/LT1 intakes bringing up the rear.
Anyway, the numbers are rough generalizations but the point is that there is no single "best" intake. You get the best results by matching the intake to the RPM range where the rest of your engine package produces peak power.
Post some details on the cam and heads, rear end ratio and transmission you'll be using and people can give you some more specific info.
Regards, Michael
Old Aug 18, 2006 | 11:18 PM
I'm running a HOT CAM W/1.6 roller rock., 64cc Vortec heads, 3.27 rear, rebuilt 700R4 to handle 450H.P. with lockup conv. 2200 stall. Bunch of other stuff in my signature also. I like the sound of the super ram. The mini ram from TPIS said they could drill the holes for vortec heads for $75 prior to shipping. I haven't asked Accel but the advertisment for the Super ram said will not fit Vortec. I'll call them Monday and see what they can do. Here is a link to my motor. It is currently being installed http://www.sdpc2000.com/catalog/1578...rip-Engine.htm
Old Aug 18, 2006 | 11:53 PM
grammerman's Avatar
I think the Super Ram would definitely work out best with your package. I know where a TPI base is for sale that was converted to work with Vortec heads, it was a TPIS big mouth. He wanted about $250 for it, PM me if you're interested and I can dig up his email address. If you went with the SuperRam you'd just need the plenum and runner set then.
Later, Michael
Old Aug 20, 2006 | 01:51 AM
Grammerman seems to have covered the bases. Personally I think the Superram is the way to go. Sure the MiniRam makes more HP.....above 5500 and up to 6500. Aside from that, the Superram is the king. But I don't want to rev that high. Superram doesn't lose torque. Also maintains the EGR setup. When LT1's were new, Lingenfelter would keep the LT1 setup for the manual cars but put the Superram setups on automatic cars.
Holley tends to have the best value to performance ratio.
I have no experience with Vortec setups.
Old Aug 20, 2006 | 02:09 PM
YenkoST's Avatar
SuperRam=more low-mid range power
HSR=more mid to upper range power
miniram=upper range power(more cubes, agressive cam, and some nice heads would do this setup alot more justice)
For your application the SuperRam would be a great choice...teh HSR is another great choice....its just cheaper.
Old Aug 23, 2006 | 01:16 PM
1racerdude's Avatar
The Holley stealth ram will get it DONE even on a 383 if your heads will flow with it'
Old Aug 23, 2006 | 04:28 PM
YenkoST's Avatar
Yes it will.....wonder how I know but I think its for a 350.
Old Aug 23, 2006 | 05:08 PM
1racerdude's Avatar
Depending on your heads it will work on either. It will still line up but ya may have to redrill the bolt holes. For an LT1 ya got to take it to somebody to get the flat part around the hole machined to the bolt head angle as the bolts are at a different angle than a SBC.
Old Aug 24, 2006 | 11:59 AM
onefastgta's Avatar
If the stealthram was out when I bought my miniram, I wouldn't have bought my miniram. Best hp for the dollar as far as TPI intakes go.
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
Stephen68
Oct 16, 2015 03:50 PM
CARiD
Sep 30, 2015 05:44 AM
95craz28
11
Sep 12, 2015 07:47 AM
