battery drain when cranking
Old Dec 1, 2006 | 07:46 PM
ienotsr's Avatar
i haven't started the car in over 6 months.i put on new spark plug wires and cranked it.it wouldn't start.voltometer droped to zero when i tried to start it.i got told my alternator was dead right before i stopped driving it.the battery wasn't being recharged while driving.but would that cause this.i put a brand new battery in before i cranked it.i'm thinkin starter.i got it to fire up twice.but no more.sounded fine when it turned over.
Old Dec 2, 2006 | 12:17 AM
LesPaulGoth's Avatar
How long are you letting it crank for? If you are sitting there for a few good minutes trying to get it to start, you will run the battery dry. If you get it started and your voltage is around 8-10 volts (I think, its the lower number on the dial) then you are running with a bad alternator, ideally you are looking for a 14-15v charge.
Old Dec 4, 2006 | 07:29 PM
ienotsr's Avatar
yup.was deffanatly the alternator.got it fixed.
nosliw
Apr 26, 2015 02:13 PM
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
silvermansteve
Mar 4, 2015 05:02 PM
Sandersen511
Jan 13, 2015 03:49 PM
