True Dual exhaust
Or you could do something a little radicle like this:
http://i6.photobucket.com/albums/y20...a/IM000279.jpg
this thread has pics of sevral setups...granted on 4th gens... but the underbody is nearly identical.
side by side over the passenger side is the way to go...but $$$
my 1989 firebird formula has true duals on it 2.5" pipe out both sides right in front of the rear tires, only cost me $290 - But you will have to use some type of bullet mufflers due to the space. Other than that you can have them run it over the axle on one side like they say.
On my 82'.....
Ive got true duals on my 82. Bought em off of ebay, but they came from Summit. A friend of mine with a lift, torch and welder installed them. They turned out to be a HUGE P.I.T.A., and took this guy 4 days to install. (He was a professional exhaust guy). It sounds great and added GOBS of power to the car, but Id advise you to stay away from the Summit kit unless you have full access to a shop, lift, welder and torches (to rebend tubes).
Oh, and the supplied mufflers didnt work. I had to substitute a set of glasspacks. But holychit does it sound good.............
guionM
9
Aug 29, 2002 01:48 PM
