87 camaro Iroc/ Electronic auto tranny??
Re: 87 camaro Iroc/ Electronic auto tranny??
shifting is controlled by the hydraulic valvebody
the tcc is operated by a solenoid in the valvebody
the 93 lt1 uses a 4l60 which essentially the same as a 700r4
94 comes the 4l60 e, which is an electronically controlled valve body
I'm installing a holley commander in a 87 iroc. How do I install it without out it effecting the electronic torque converter lockup???
are you using the CM 950 ecm or are you staying w/ the factory ecm? if staying w/ factory nothing to worry about. but if your goin w/ the cm950 i just suggest wiring up a toggle switch.
They also make lockup kits for around $100.00 b&m and tci make them also The toggle switch idea works until you forget to turn it off a few times and it frys the TCC then its big buck rebuild time ...
cmsmith
Jan 5, 2015 07:04 AM
