89 305 tpi, wount idle
Old Oct 29, 2006 | 10:52 PM
ba96ta's Avatar
I just got a 89 305 tpi A4 formula as a project car. The problem I am having is it wount idle. When I start it up it idles ok at 800rpm for a second then drops down to about 300 then reves up to 1000rpm and goes back and forth till it dies. When I am driving it. It goes fine if its above 2000rpm. And at WOT it doesn't heasitate at all, has plenty of power. I was thinking maybe MAF, TPS, or Map it seems like its searching for the right A/F ratio. Anybody out there ever have this proublem? Any suggestions?
Thanks for any help
Joe
Old Oct 30, 2006 | 02:45 AM
1987IROC350's Avatar
Mine did something similar but it was the TPS. Is the service engine light on or on occasionally? Remeber you can use a paperclip in the 3rg gens to get the check engine light to flash you the codes. I'll post the instructions just in case you have not seen this. http://www.yjshadow.com/ALDL_codes.htm
Old Oct 30, 2006 | 07:54 AM
87DJP2001's Avatar
Check for a vacumm leak.
Old Oct 30, 2006 | 08:23 AM
CamaroJosh's Avatar
Mine does this occasionally and it will idle rough for about a minute and the SES light will come on then it will die.... but the second time i start it up it works fine.. never been able to figure out what it was
Old Oct 30, 2006 | 10:03 AM
ba96ta's Avatar
Thanks for the tip 1987IROC350. Its not throwing any codes, no SES. It costantly goes from 300-1000rpm warm or cold. I think it may be the egr valve stuck open. But I will check for vacuum leakes.
Thanks for the replies
Old Oct 31, 2006 | 09:13 AM
formul8's Avatar
Have the original injectors ever been replaced?
Old Nov 1, 2006 | 09:37 PM
slayer_4213's Avatar
my 87 did the same
try replacing the throttle body gasket
F'n1996Z28SS
Aug 23, 2023 11:19 PM
STR FTR 1
Feb 10, 2015 10:36 PM
91 Redd Sledd
Aug 14, 2002 02:02 AM
AutoRoc
Aug 7, 2002 11:45 PM
Carguy00
Aug 6, 2002 10:25 PM
