1984 camaro steering column?
Old Aug 26, 2006 | 01:04 PM
CamaroGUY07's Avatar
Ive been debating about whether or not to get this camaro for dirt cheap..only problem i have is that im afraid i wont be able to fix it...all it needs if a flywheel for the 350motor, and a steering column...im afraid i wont be able to find the parts i need. Is there like more than one year that will fit on a 84...for example will a 86steering column fit in an 84? or any other year? thanx in advance...also whats a pretty good after market flywheel that i should look into since i already have to change it..the car is a 84 auto 350 z28...? thanx again.
Old Aug 26, 2006 | 01:23 PM
Dave89IROC's Avatar
Re: 1984 camaro steering column?
why does it need a column?
if it is just loose, fix it, it broken(stolen), again, just fix it
Old Aug 26, 2006 | 02:18 PM
i figured it would be easier...but i will have to look into reparing it...thanx for the heads up
Old Aug 26, 2006 | 04:25 PM
2kflhr's Avatar
A lot of them loosen at the tilt head. All you need to do is remove the wheel and re-tighten and loc-tite the torx head screws. I've done this before with other tilt columns.
Old Aug 26, 2006 | 05:14 PM
Dave89IROC's Avatar
look here, should help if you decide to fix it
http://www.thirdgen.org/steeringcolumn
CaRParts102
Dec 6, 2014 08:45 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
carcrazyQT
Sep 17, 2002 07:54 AM
carcrazyQT
Sep 3, 2002 02:51 PM
