please read..thanks
Old Aug 28, 2006 | 09:50 AM
OneFreakZ's Avatar
Angry please read..thanks
hey guys i ran into another problem with my 89 camaro i left my car sit for one full day without starting it this morning i go to start my car and nothing no lights come or anything now it has a new battery and alternator...any ideas guys what might be wrong??>..thanks
Old Aug 28, 2006 | 10:50 AM
Wishmaster's Avatar
Re: please read..thanks
wiggle the wires on the batery and make sure they have a good and tight connection is 1 thing you can try.
Old Aug 28, 2006 | 04:01 PM
ghillie's Avatar
I had this problem with my 82. Turned out to be a bad battery cable. The negative one to be exact.
E
Old Aug 28, 2006 | 06:02 PM
OneFreakZ's Avatar
Unhappy Re: please read..thanks
well i was looking through my battery cables and seen that the negative cable was loose so i tightend the cable but still no luck so i looked at the cables and seen that the posittive cable has some corrosion but im not sure if thats the problem or not but im going to replace the cables and terminals..it just seems to me that something is draining the battery??>..thanks
Old Sep 3, 2006 | 12:19 PM
OneFreakZ's Avatar
well guys i replace the bolts to the cables and now they are tight but still getting my battery draind from some where ????
Old Sep 3, 2006 | 05:23 PM
xpndbl3's Avatar
check with an ampmeter for the amp draw then repost back your results.
Old Sep 3, 2006 | 11:27 PM
IROC-T's Avatar
Do you happen to have an aftermarket CD changer that uses an RF modulator through the radio? If you do that could be your problem, mine was drawing my battery down. Just a guess, something to check.
Old Sep 3, 2006 | 11:43 PM
OneFreakZ's Avatar
Question Re: please read..thanks
no cd changer...what do you mean to check the amps to the alternator????before i start the car???..thanks
Old Sep 4, 2006 | 12:33 AM
xpndbl3's Avatar
no i said check the amp draw with an ampmeter, for a description of how an ampmeter works check it out on google. it will tell you an amp draw with the car off and no lights on. report back with that number.
Old Sep 4, 2006 | 09:16 AM
OneFreakZ's Avatar
ok so im little confused here..i know whats a amp meter but the thing is where do i make contact too??battery or alternator??..thanks
Old Sep 4, 2006 | 01:51 PM
xpndbl3's Avatar
you disconnect the positive cable on the battery. you then place the ampmeter in series with the battery and the cable. write down a number and post back. So battery + post, ampmeter lead, ampmeter, other lead, other part of positive battery cable.
Old Sep 4, 2006 | 04:53 PM
OneFreakZ's Avatar
ok sounds simple enough ill do that tomorrow...ill let you know what i got..thanks
Old Sep 6, 2006 | 06:02 PM
OneFreakZ's Avatar
ok so heres what i did i load tested the battery is read 700 the alternator read 14.2...hopefully this helps..thanks
Old Sep 6, 2006 | 06:10 PM
OneFreakZ's Avatar
so now i know that the battery and alternator is good i was told that i have a sort somewhere??>please any ideas on what to check??>.
